Im in the process of building a ef hatch with a b18b and running 20 or so lbs of boost. Im wondering what piston rod setup you guys would suggest? What is everyone else running and pros and cons on the setup?
B18b block build suggestions.
Vitara is for a single cam bud.
For a rod piston combo go with eagle or manley turbo tuff rods. They hold up great and are relatively cheap. For pistons i stick to wiseco or cp because they are well known and very reliable but there are hundreds of companies out there.
Oem head gasket, ARP throughout the whole build and use king or ACL bearings. Bring the block to a machine shop and get it line honed and check all of the clearances so that you dont get any crank walk/burnt bearing issues.RIP NHSWAPS13203
I heard that i should use oem bearings. Ive heard it both ways though.
