stock em1 turbo build
  • stock em1 turbo build
    ok so i wanna turbo my em1 but keep it mostly stock im thinkin arp head studs cometic gasket proly cams intake manifold injectors fuel rail 2.5 inch exhaust wat would be a good kit to make somwhere around 250-300 whp
    with 10:1 compression your limited with how much boost you can run safely. just leave it stock. get good bolt ons and a tune
      idk bout the cosmetic gasket, i belive that would raise your compression, and that's not what you would want if you have stock internals. you probably want to keep your compression low right? neways id say godspeed, turbonetics or ebay, depending your budget. idk dude, is that your daily?
        yes it will be my daily and internals will be stock only looking to boost like 7-8 pounds with a good tune
          fullrace rev hard or peakboost all good kits. cometic gasket is not needed oem honda is perfectly fine, arp headstuds yes, intake manifold not needed, minimum 3in exhaust, stock fuel rail is fine, itr or ctr cams would help (need to replace valve springs to dual) 550cc injectors.
            x2
            single cam ham
              you dont need a 3 inch exhaust for 300 whp, but why buy an exhaust twice, 2.5 is fine, i agree with mark though, im only running 440's arps intake mani fuel rail walbro 255 and the stock headgasket. ITS ALL ABOUT THE TUNE, spend most of your money there, evans is the way to go!
                quoted from evans
                Turbo
                We recommend a minimum of a 3" downpipe, test pipe, and exhaust
                i am big fan of evans and follow his guidelines alot he has alot of ood information on what to use
                  12:5:1 comp pistons, and a good turbo kit will get you 300 whp all day!
                    thats how i blew my vette up!!!!
                      i dont realy wanna touch the internals
                        You don't have to... Read
                          thanks for the advice now i have a starting point for the build
                            fuck boost....... b20 vtec... all motor..... much more reliable
                            EM1-860-CTmember..1...
                            J-SWAPS ....860-457-8335
                              quoted from evans
                              Turbo
                              http://articles.evans-tuning.com/200...rt-charts/#200
                              :/ hahaha, my hi power is like 2 and a quarter killmyself.
