im thinkin i got till tuesday to decide
all motor or turbo lmk ctvv
go with the gsr..run allmotor with an intake mani,tb,cams,header,exhaust,and a nice intake setup...then down the road when funds are right,sell the cams and header and boost that snizz.!!!!!ThE GoOd DiE YoUnG!!!!!
Originally posted by ekwemo View Postyea im the saim allmotor i whanted to do boost but u thunk sopending the money on the kit is all naa...u gota make shure your block is built for terbo nomater what u could do a a smaal bolt up terbo on a stock ls motor but do u reall whant to waste the money u have nd blow it couse most likely tyhats what might happen if u dont rebuild the bothem end of the block new berrinf ceank,rod,shotpean the rods or go with upgrade i have a ls block thats set up for terbo at 9.1.0 cr if thats what u really whant to do the block has only about 500miles as well i haddd gotten it from my boy but i whant to go gsr all motor i have the head it all done all i got to do is change the valves to the flat ones n if i cant find a gsr block im tacke the rods n pistons out of my ls block nd put the new ones i just gotten ihave the pct ctr piston there high com pistons nd i will need to get some rodes as well also but its up to u on what u whant we cant tell u what to get we can tell u on what u will have to need for what motor build u wanna do if turbo cool theres tech up that will help u on what u will need to do n get or if u whant to do all motor thers tech up as well for that.. chooice is yours broo ..by all means have funn doing it lol...nd good luck motor buildenD and G auto member #5
