I plan on running a direct port nitrous set up on my high comp motor...I'm not sure what size injectors I should use...any sugestions I don't plan on spraying 2 big of a shot and its for a d series motor
nitrous help
running a wet shot u would need to upgrade on fuel pump and injectors cause once you spray nos+gas together u lose pressure to youre fuel rail.. sooo most deff. upgrade atleast your fuel pump to make up for loss of pressure. if u have the $$$ upgrade fuel pump, regulator, and injectors... just my opinion
Originally posted by KILLERFERIO413 View Postrunning a wet shot u would need to upgrade on fuel pump and injectors cause once you spray nos+gas together u lose pressure to youre fuel rail.. sooo most deff. upgrade atleast your fuel pump to make up for loss of pressure. if u have the $$$ upgrade fuel pump, regulator, and injectors... just my opinionFollow me @bolacan413
Follow the build @k_insight
