need help with oil return and feed line
  • need help with oil return and feed line
    i need to know the size of the oil feed and oil return i should use on my singe cam d16y8. i just need to know the fitting size that goes into the block or what i need to use. thanks ctvtec
    hit up my cell if you guys wanna help
    860-597-7226
    Feed - 1/8 NPT
    Return -10an
      What size is the fitting that goes into the block? And is that a t fitting or something so I can still use the oil pressure sensor
        Bump need help asap
          got the oil feed line custom mad by fluid dynamics in manchester....shit looks mad clean and worked out really nice and they sell the t fittings...i highly recommend them. you walk in tell them what you need and they make it for you right there
