Turbo help
  • Turbo help
    I got a motor that fully built for turbo application but i dont know shit about turbo someone please tell me what size i should us trying to get big numbers
    nobody can tell you what size to get. and dont worry about making "big" numbers...that will come trust me.
    you have to make sure you have all the RIGHT parts and they are all working 2gether well...fuel, spark, getting air into the motor, fuel, traction...etc.
    I did a customer car with a greddy turbo kit on a STOCK ls vtec with 750 rc's, 3inch exh, and 2.5 ic piping, and ram horn manifold make 323whp on 14.5 pounds. so its all about the application
    if you want drop me a pm and give me a run down of your motor set up and I can help you in the right direction...or you can come to my shop depending on your location lol.
    Team T&W
    Winning is the only option
      Sohc or dohc, I sell SPA turbos, I have a new spa 5000 that is good for 500hp, or a spa 7000 good for 700hp. Prices range from $600 -650. Post your build, these are t3 single wastegate.
      Crx 18 psi 441-308
      crx. 20 psi 400-270 DYNAPACK
