hi i juss had a motor recenlty build and now it overheating but it goes up and down ..but over heats allot and the resovor overfills...and another thing is i juss purchased a new turbo and at first it was leaking oil from the exhaust it still kinda does but when t ideal a large amount of white smoke comes from it...can some one help me
over heating and white smoke comeing for the turbo
check your compression, it sounds like a head gasket or warped head. what prob happened was the head gasket couldnt handle the pressure made by the new turbo and started presurising the coolant system which is why theres over flow (the coolant cap cant hold back that much pressure) and the white smoke is water that is geting into the turbo or the cylinders and is burning. def check you compression though. over heating could be because its losing coolant and cant cool itself down.Last edited by headsup7up; 04-16-2008, 12:11 PM.
Originally posted by c20h25n3o View PostIs the turbo coolant cooled? Or jsut oil cooled?
White smoke doesnt just mean anti-freeze, guys....
If hes 100% sure its coolant, than its comming from the block/headgasket most likley. If its jsut white smoke, the turbo could be shot.
When my turbo went, it blew HUGE amounts of white smoke, and i thought it was the headgasket for sure. Turns out it was the turbo, and nothing else.
If it smells sweet, and your sure its coolant, that my finger points to the head gasket/block/head.
If its jsut white smoke, it could be the turbo, or a number of other things.
Does the downpipe have any exsessive oil build-up in it? What type of turbo?
Edit: I re-read that its over heating and his coolant overflow tank is filling up....Time to look for a head gasket.... (ill keep the info up that i just posted, incase it can help fellow members in the future)
-William
the turbo should either be oil fed of have its own reserve. the white smoke could be exhaust smoke if you cracked the head but if you turboed the car and didn't upgrade the radiator you run a chance of overheating the car. an aluminum radiator can handle the heat and the pressure better then stock or oem replacement however your going to need a slimmer fans.. i ordered mine through mishimoto. you need to be car by running all that heat that you didn't warp the head. BTW when turboing a car its always a good idea to start with a new multilayer head and valve cover gaskets no matter how new the others are. Also as an after thought after you fix this problem you might want to check your piston rings.
Benefits of Becoming a Member
Can you simply tell if Runescape is a great game maplestory powerleveling or not without you becoming a member? The answer to that would be, NO! Well you can make a few predictions about Runescape and see the moral of the game when being a regular user and not a member but becoming a member brings a whole lot of additions to Runescape that you would never see if you were not a member. Being a member of Runescape has so many benefits and I will try to list them all here for you. Runescape tells you them, but I'm going to detail it a few features for you here. runescape money
oforuCOM
I was a Raid Leader in World of Warcraft. The raid needs more time andwow gold. Ample wow gold is necessary for RAID. I am a loyal customer of Brogame. Very helpful.William Letourneau--------------------------------------------------------------------------------Not only the fast delivery of wow gold, the customer service is excellent. Anyway, it’s a nice experience to buy wow gold here.Joseph Dovel wow gold
oforu.com
Oforu News Update- Age of Conan gold and power leveling service startedwow goldthe New MMORPGwow gold Era- Accompanied with Age of Conan coming, we will offer you the best service and cheapest price at the same time when others havn't familiar with this game. Unparelelled Reputaion and professional service will never change for this new wow goldwow gold
welcome to massage in shanghai
I fully support you, this is my task. I hope you better:Shanghai massage|Shanghai escort|massage Shanghai|massage in Shanghai
