oil line
  • oil line
    Where do i tap into to run my oil line?
    Ef/Ek/DC5
    oil pan for the drain line and for the feedline it goes with a t to where the oil pressure sensor is on the block between the intake manifold and the oil filter
      got it thanks
      Ef/Ek/DC5
        not to jack your thread bro but is there a "good" vs. "bad" spot to tap your oil pan... or does it not matter..?:confused:
          yes.. you need to put it in the bigger part as close to the top as possible
            word
            Ef/Ek/DC5
              cool thanks
                The return has to be as close to above oil level while the engine is running, oil level drops a quart when running so it doesn't need to be so far up it blocks oil pan threads or is a pain in the as to work with, and the oil pan is under constant suction since the oil pump is a positive pump so oil is always moving and it doesn't really matter where the return is as long as its 10-an or bigger.
                Turbo 86' 325i, 20psi of Megasquirt lovin'.
