what is the proper line size -3 or -4 for a t3/t4 turbo. are people running oil restrictors? if so what size?
lastly what are the symptoms the turbo is being fed to much oil???
the motor is fresh, the turbo doesn't smoke under load the oil return is working fine, im currently using a -4 with no restrictor.. If i let the car idle for a min or so it will smoke, when driving hard it doesn't.... plugs are clean compression is fine.
thoughts?
thoughts?
