I have a question
  • I have a question
    So I've been doing a lot of research an I need some opinions I'm planning on putting a h22 in a integra. I've been researching it an I'm getting both positive an negative answers everywhere I look. What do you think about let me kno
    Always on that fire
    h2b or h22 with h trans. only h22 I would do is with a lsd trans and shorter fd ratio
    Follow me @bolacan413
    Follow the build @k_insight
      U already got the b tranny. Just get a h motor. I hear h2b fits better and u wont have axle problems. Fyi u can just slap that b tranny on the h engine without using the adapters but u will only be using couple bolts to hold them together and ur clutch wont last too long lol. <--- that's if u wana go cheap.
      But do it right, get the h2b adapter and it will be beast
        H and b transmission have same bolt pattern just cut the block and you can bolt up the b series transmission look it up on ht
          da axles work fine or you can even get already custom fitted axles for like $250
            Ok I still want ur swap I'm just trying to unload this swap of mine
            Always on that fire
