Alternator (need help)
  • Alternator (need help)
    I have a 94 obd1 civic with the obd1 harness and i already swapped the engine with a obd2 ls ..i already changed the injectors and dizzy and harness to obd1..the only problem that i am having is with the alternator plug so i need someone's help..
    Obd2 plug:black/yellow
    white/blue
    white/green
    white/red
    obd1 harness plug:blue
    white/blue stripe
    black/yellow
    white/yellow
    ****how would i wire this up?????
    Originally posted by knuckk
    I have an obd1 b series alternator if that helps..... what's good with the 4dr lmk I'm down send some pics if you still want my hatch
      ^^^ Like Lefty said, just go get an OBD1 B-Series Alternator, your done. I also have one if interested.
        me too if intrested lol , thats all you need man
        Build In The Making!!!! BackYard Built Not Bought!!!!
          google that shyt
          *S14 Kouki *
            OBD1 :::::::::::::::::::::::::OBD2
            Black /yellow::::::::::::Black/yellow : IG
            White /Blue::::::::::::::white /blue : Dash Charge light
            White/ Yellow:::::::::::White/green : Alt Control -OBD1 ECU pin A16 /OBD2 pin A19
            Blue::::::::::::::::::::White/red : Alt Switch - OBD1 ECU pin D9 /OBD2 Pin C15
            thank you!!!:)
            ~StayinFRESHSINCE1982~
            SPUNKY MONKEY CREW MEMBER #1
            203 CREW MEMBER #33
              thanx for the help guys i figuered it out already...its exactly how mr layy said....
