95 teg bogging need help asap
  • 95 teg bogging need help asap
    Ok gotta 95 auto teg,wen I give a lil throttle itz fine but wen I tryda give half throttle or so u can hear da throttle open but from 1000-4000rpm da car hesitatez an won't pick up unless I give full throttle,top end seemz fine but wen I let go of da gas an coast I hear a missfire/stutter while decelration.wut I've done so far is plugz,wirez,fuel filter an injector cleaner/treatment,timing checked,no cel light da motor is bone stock.anybody help???????
    try another well-known distributor and see if it works. then let us know if it worked.
      Das Wut I'm bein told so far but can't find a decent 1 4 less den 250$
        yea i wouldnt go out and pay that much for one, you cant borrow someones quick to see if it would fix the problem? junkyard?
