eg help ??
  • eg help ??
    Ok so im stumped any help would b appreciated.... my hatch gets little to no power when ignition key is in pos IG3, does not crank or nothing at all ( no click nothing) and my cluster does not show check eng or any lights for that matter ...shits crazy as fuck!
    To top it off all fuses r good smh!
      Same with mine it's like it doesn't like the cold my car will crank fine one min but then like a night like this with frost on the roof it cranks real slow or just won't crank and I have a bn batt
        ^ I cant even get it to crank its like as soon as I hit the key to pos3 your suppose to get the check engine light , oil press light and abs if u have abs wich I dont ....
          The best part is that I was driving it fine I stopped shut it offf ran inside for a few min n came back n iys nightmare central lol!
            Bump gl
            J.R. Built not Bought
              This happened to me 2 days ago so what I did was prime it a couple times and bam started right up
