Anyone having problems with the walbro fuel pump half tank empty????
  • #16
    make sure your float isnt hanging up on anything....cause if it is, it will not go all the way down and give u an inaccurate reading of how much fuel u have, happened to me in my old ek coupe
    • #17
      Make sure its installed right as well. I remember when I did mine I just tossed it in at first but it depends what kind of car you have. EF's can only go in one way but others are different. If you dont rest that pick up on the bottom of the tank it won't be able to get the fuel there.
      WTF?! Racing.
      ________________________________
      Blowing Smoldering Holes in Honda Motors Since 2005... ish.
      • #18
        Wow I never heard of this. Mine works fine. The only problem I heard about em' was that you need to put bigger gauge wire and add a relay cause the ecu doesn't have enough power to power the pump.
        Greatness is only 1,320 ft. away!!!
