Im new to this forum thing & i was really just looking for some help/ideas on what tp do. I have a 97 prelude base model. I have a few mods done...cat, catback, intake, wires...just starting out. I have beev having trouble with my SS auto trans. When i start the car The d4 light blinks at me and tthrows my cel. It seems to do this when its raining or wet. I took it to my local shop and they said i have an intermitent electrical problem. They took the codes and they say pressure control solenoid valve b and tcm and linear solenoid. But the problem goes away when i simply turn the car off and turn it back on again WTF!!! Let me know what i can do
97 Prelude Transmission issues...need some input
pull the solenoids off. they are located in the front of the trans. you can flush they out and test with 12v to one terminal and ground to the other. you should hear a strong click in the solenoids. you can spray them out with parts cleaner to try to clear them out. if the issue is typically only when wet the connections may be getting moisture in them. pull the connections off and try to give them a good clean. look for corrosion.
