long story short......i bought a car off this kid that just told me that the only thing wrong with the car was that the center bushing was not it....so u can take the shifter and rotate it around in circles...come to find out the car use to be auto....dont know if that any help....point being its hard to throw it into gears cuz i dont know where they are at....its really lose like i dont have bushing or pins holding it together its really loose...and i dont know what could be the problem...dont want to keep driving it to ruin the clutch ......I HAVE NO IDEA WHAT THE PROBLEM IS?????any advice or answer would be appreciated....thanks
Help plzzzzz
Sounds like the 2 bolts that hold the linkage to the underside of the car arnt there and ur shifter is just floating around ontop of your exhaust. It shouldnt mess up your clutch at all but im sure its a pain in the ass to shift. Or the bolts are there but the rubber bushing isnt so its all loose pretty easy to fix if thats your problem just 2 12mm bolts jack up the car and check it out.
i dont see what he would need to weld everything on the assembly is bolts. unless the two bolts that hold the shift linkage plate to the shifter broke but in that case ud just need new bolts. if its not the two bolts that hold the big bushing on the end of the linkage the only other thing it could be are the two bolts going between the linkage plate and the shifter (sorry kinda hard to explain) to replace those bolts u will have to take the whole assembly down and replace whatever bolts are broken. i just replaced those bolts on my ek cuz they where all rusted and one just broke off.
Originally posted by DBBOY203long story short......i bought a car off this kid that just told me that the only thing wrong with the car was that the center bushing was not it....so u can take the shifter and rotate it around in circles...come to find out the car use to be auto....dont know if that any help....point being its hard to throw it into gears cuz i dont know where they are at....its really lose like i dont have bushing or pins holding it together its really loose...and i dont know what could be the problem...dont want to keep driving it to ruin the clutch ......I HAVE NO IDEA WHAT THE PROBLEM IS?????any advice or answer would be appreciated....thanks
Where you located maybe i can help you out inbox me
