Delete
Need Help: DA Integra motor mounts installation
To do the rear you have to take the transmission mount off, put a jack (good one) under transmission for support. Remove t bracket , remove bolts from rear mounts ( on the subframe) soon as the new mounts in, start putting the t bracket back on ( have someone pull the motor towards the front while doing this. After t bracket is in, jack up the transmission to desired height then bolt up the front mount the bolt up the transmission mount. And you are done.Down Since 09 ...
Mugen Inspired DC5
