I have 2 crxs, one black si and one white. One had an ls (white one) and the other had a d16 vtech (balck one). Im trying to swap engines between cars. I already took the the engines out and installed the d16 in to the white one. I used the harnes that was in the white car because there was some plugs that did not fit, but the plugs for the distributor were diferent as well. I try to swap the plugs for the distributor so they would fit with harnes. Now the car wont start. Should I just buy a new distributor obd0 for the d16? and an ls obd1 for the b18?
Need help with swap
Originally posted by berrios1 View PostI have 2 crxs, one black si and one white. One had an ls (white one) and the other had a d16 vtech (balck one). Im trying to swap engines between cars. I already took the the engines out and installed the d16 in to the white one. I used the harnes that was in the white car because there was some plugs that did not fit, but the plugs for the distributor were diferent as well. I try to swap the plugs for the distributor so they would fit with harnes. Now the car wont start. Should I just buy a new distributor obd0 for the d16? and an ls obd1 for the b18?
Originally posted by JDMEGVTEC View PostSomeone help this lucky bastard out having to crxs god bless you haha
1989 CRX Si (Yellow)
1989 CRX HF (Light Blue)13203
Originally posted by H23VTECLUDE View PostI must be one of those Lucky Bastards too then. ;):D;):D
1989 CRX HF (Light Blue)Last edited by H23VTECLUDE; 01-11-2009, 05:18 PM.Money Ain't a Thing! Crew Member #5
Originally posted by berrios1 View Postthe black one was converted to obd1. It had the jumper harnes and it had a p28 ecu. the white one was running on obd0.
Whats the problem no spark, no fuel, no crank, what?13203
Originally posted by berrios1 View Postno spark. it cranks and it does throw fuel.13203
Would you be willing to pay for the repair? Is the car covered/Garaged? I live in Enfield, but would be willing to do mobile Tech Service if the money is there. LMK.13203
