need help on my ej1 asap plz
  • need help on my ej1 asap plz
    i need help on my ej1 windows they dont wanna go up or down what can it be only lil piece of info will help
    thank you
    EJ1 STILL BUILDING
    im assuming you check your fuses? if so maybe the window regulators are bad
      ^^^x2
      :cool 2039357121
        check your window switch ( the actual buttons you press to lower the windows) common problem with hondas
        *S14 Kouki *
          i check the window switch and i chage it but didnt check the fuses
          EJ1 STILL BUILDING
            andd thanks for the help and info
            EJ1 STILL BUILDING
