idle problem help
  • idle problem help
    Okay so when my car is in neutral is will rev/idle to like 2rpms then drop till 0rpms(repeatedly) but its weird because sometimes it stops?? or it will stay just above 1rpm......could this be I need a new throttle body???? Help me out ctv I want to get this fixed
    sounds like a vaccum leak
      okay ill check that out. but is that the only thing it could be??
        Check your coolant it could be low or you might have a air pocket and have to bleed it
          X2 could be a tps too....
            sounds like ur iacv
            D and G auto member #5
              Bump the coolant leak or low coolant, thats #1 then check tps, check iacv and if it still idle searches check the fast idle thermo valve.. youtube it, theres a good vid how to correct it if that it. Personally, (unless the tps is damaged somehow from some impact i have only seen 1 bad tps on a honda in 13 yrs. first see if ur iacv is leaking(grab a can of brake clean and spray the thing down and see if it levels out(stops) next, pull the intake tube off and see if u can plug the hole the iacv feeds from. it it levels out, its bad, if not grab a multi meter and a manual, then check the thrermo valve(its attatched to the throttlebody)
              96-ek hatch b20vtec - daily
                here u go mang just click and watch
                  thanks for the help ill check all of this out.
                    mines does same
                    90 DA integra-sold
                    2011 Chevy Cruze<---yea yea i know
