heat........
  • heat........
    my heat is weak can i make it stronger and how.........its cold out there help a dude out...lol
    Power invertor plus space heater equals warm lmao
    I Love Blunts N B!tches Crew Member #1
    I Love Haters Crew Member #2
    I Hate Low Ballers Crew Member #2
    :p:p
    $XBOX 360 GamerTagz$
    Spinach Rav
    Im Flithy
    Gag On My Glock
      wow thx for that
        yeh i got a 92 da..........can i put a new blower in??>..wat can i do for more powerful heat??....shyt nd how can i fix the vents??..cuz heat doesnt go through the feet section........
          bump....................
            Try replacing the heater core... its prolly getting clogged.
              Most likely a bad Hot water valve. The hot water valve allows coolant to flow thru the heater core, so if the valve is not open, very little coolant being pumped thru the heater core = Little/No Heat.
              Dis-connect the temp select cable off of the hot water valve & see if you turn the swing arm, or check for the swing arm being stripped from the actual valve. If it dont feel right, replace it. Hope I was able to help
                Heater Core's almost NEVER go Bad. Sorry, good idea though, if it was a GM car.
                  you could always go to autozone and get a 162 degrees thermostat
                  ~StayinFRESHSINCE1982~
                  SPUNKY MONKEY CREW MEMBER #1
                  203 CREW MEMBER #33
                    ill try it thx you
