Obd0-Obd1/ dual point to multipoint Conversion help needed!
  • Obd0-Obd1/ dual point to multipoint Conversion help needed!
    I need some questions answered. someone text me or call im trying to drive this car soon. I have wiring experience and know how and where everything goes for the most part. just little stuff like getting rid of the injector resistor box. I have a obd0 and obd1 multipoint harness. I don't have the original dual point harness. could I de-pin the cabin harness plugs on the pass. side and wire it from the ecu pins up to the plugs? i want it to look stock and clean. I have the obd jumper harness and dizzy jumper also. Someone that has done this before and knows what they are talking about please help! i don't want my time wasted
    ***I found a couple write ups for the future if anyone needs help these have helped me out a lot
    How to Convert DPFI TO MPFI: A Wiring Guide SUPPLIES: 1 black 0BD0 ecu connector w/ pins 1 0BD0 MPFI engine harness Distributor plug w/ wires 1 0BD0 MPFI ECU 1 Injector resistor box (w/ enough wire to solder to) Various wires in colors close to factory colors as possible heat shrink tubing...
    ECU JUMPER HARNESS DIRECTIONS
    I got a few links in case if anyone ever needs help doing this.
