Please help out
  • Please help out
    I got a 96 teggy auto and i want to know if there any place around here in ct that does auto to manual convertion or any one that knows how to do it legit the right way so please let me know anyone.
    93 civic sedan EX-project
    Anyone can do it for the right price. Where are you located?
      i can do it as long as you have all the parts neccessary.. ive done eg coupes integras hatches.. lmk pm me for more info
        Bump Mantyme knows what hes doing he did the clutch on my old teg widd no prob
          I wanna put a ls on mine so Ill get the swap but what more do I need?
            you need
            clutch line
            master cylinder
            slave cylinder
            5 speed pedal assembly
            5 speed throttle cable
            Auto to manual Conversion mount...
            thats it if your getting a full 5 speed swap...
            but if you wanna use the motor in there now
            you will also need
            flywheel with bolts
            clutch
            pressure plate with bolts
            5 speed transmission
            b series shift linkage with bolts
            b series starter with bolts
              you need
              clutch line
              master cylinder
              slave cylinder
              you will also need
              flywheel with bolts
              clutch
              x2 with all this its an easy bolt in process...this is the RIGHT way....the most important piece would be the hasport auto to manual swap mount for the trans side...with out that there will be some welding involved...
                Ok so I'll just use the engine that I have and I'll the part so how long will the process take and ruffly how much would you charge mantyme?
                  you need
                  clutch line
                  master cylinder
                  slave cylinder
                  you will also need
                  flywheel with bolts
                  clutch
                  Bump!!!!!!!
                    i got a pedal assembly for sale!!! hmu 2037880642
                    ~StayinFRESHSINCE1982~
                    SPUNKY MONKEY CREW MEMBER #1
                    203 CREW MEMBER #33
