1.5 Honda Powered Dune Buggy??
  • 1.5 Honda Powered Dune Buggy??
    hey, I just picked up a dune buggy yesterday for 100 and I'm lookin to put a 1.5 minime in it...just seein if anyone out there has done anything like this/ anyone know what I need for wiring... would I just need the part of the harness for the ecu and the engine harness or would I need the whole thing??
    wow sounds like a cool project i would like to see that when it's done you should be hearing from some of the guys on this subject so check in every so often g/l bro
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
      basically engine harness to ecu and ignition
      My work: Flikr.
      Andres Valentin Photography
        we've already thought of this ... to try nd keep everything in the center try to use the 2 pass. axles .. keep the wheelbase short :) were u at i'd love to try nd help i wanna do this 2
          well, it's going to be a long process over the winter....i'm from the groton area.. It is a V-dub chassis...I was going to weld honda hubs right to the V-dub spindles, i'm still in the stage where I dont know what to do with it yet..I got a subaru motor and tranny that will bolt in but I want something original.. What about instead of an ignition.
          Could I just use a push button start, because i'm not going to have a dash or anything... just oil press, oil temp, rpm, and water temp?? and yeah ANY HELP is appreciated, thanks a lot guys.
          oh yeah I can only get to a computer like once or twice a day but I'll try to check as much as I can
          HOW DO I PUT PICS UP??
            u have to make a photobucket account or a diff. sharing one like that after u upload them to p.b. u click direct link and copy it then inser image nd paste
              bumpppppppp
              HIGH OUTPUT CREW #14
              95 ex b20/vtec coupe-sold
              95 ex ls/turbo coupe-traded
              90 ef si-sold
              95 lx 4dr-dd
                have u tried mayb puttin the vw axle ends on a honda axle ?
                  yeah thats what we were thinking...
                    put a gsr motor in it. lol
                      do u have an idea about the shift linkage
                        some sort of lever thing that'll get it to pivot.. kinda like 2 L's maybe
                        do u have a vw linkage?? hows that go into the vw tranny from the front or back?
                          can u get more pics of like the whole back .. were motor nd tranny are supposed to go ?? i got a comp. motor if u need i'll sell real cheap 4 this...
                          second thought dual point intake nd carb... should make it easier if thats possible
                            i beleve that the vw linkage are cables like the k series hondas
