CEL And Fuse Help
  • CEL And Fuse Help
    I started having a problem with my interior fuse
    Example interior lights, radio, clock, door ajar sound keeps popping after like 2 minutes. I put a new fuse in and the same thing happens. I've pulled the radio out and no wires are exposed or touching and it's not the cigarette lighter because nothing plugged in, so this is real mind fucking me right now idk what do look for next
    As for the check engine light I've had it one for about a 8months-1year nowidk what the codes throwing but I know I need my o2sensor plugged in put also was thinking if I plug that and it's still on due to it being swapped could it throw a code from that
    Any input or help on this would be appreciated
        Bump help please
            it could be a short.. very strange. As for ur cel, wat obd is the motor?
              it could be a short in ur fusebox jova. as for the CEL you know your gonna always have a cel, you a have obd2 swap in a ef with a custom harness. your best bet is bypassing it.
              Down Since 09 ...
              Mugen Inspired DC5
                  Light is most likely on for o2 sensor.
                  (860) and beyond
                  #DavesTuning 8608050968
                    U have a short
                    Follow me @bolacan413
                    Follow the build @k_insight
                      Theres a short somewhere, get a multi meter n check continuity..
                        Thanks fellas and at nando yea man I know just tired of looking at it now, but like ej1 sleeper said i have obd0 converted to obd1 with an obd2 motor
                          As for your fuse problem, try eliminating stuff one at a time, pull radio, if pops pull, interor light, and soforth untill u get some where!
                          For ur cel. Jump it an see wat codes u have then work from there! U can can have any obd motor or chassis and if done properly no cel.
                          NHSWAPS13203 > *
                            I was going to say the same thing. Read the code, and replace whats bad. I had an obd0 engine in my EG and i put an obd0 LS in my buddy's 00 EK.
                            Take your time and you will get it all sorted out. If you need to jump to code allyou need is a paper clip.
                            RIP NHSWAPS13203
                              How do jump to code?
