Need help asap. Startinq problem
  • Need help asap. Startinq problem
    Ok so my boy has a 90 ef 4door its was orqinally auto but they made it stick. Its use to start fine. He brouqht it to my house to do a motor mount. I did the motor mount and it started fine. We shut it off then tryed to start it back up and it wouldnt start. We have to pop start it just to turn it on. Any idea on what it is? I checked all the fuses and their qood. Im thinkinq its the qround that connects to the clutch, the relay,the starter or some wires there.
    couple ques...does it turn over at all? which mount did you change? first check all grounds and most importantly the lil wires attached to the starter..they come loose from the vibration of the engine sometimes....check fuses obviously...make sure fuel pump turns on....if all those check out ask him if that battery is any good!
      Lol I fiqured it out it was a pussy ass wire that conected to the starter that came loose.
        it allways the stupid dumb stuff after we spend all this time thinking and worrying about the worst possible thing that just happend to it and now its broken hahaa
        single cam ham
          i knew it was that! good shit!
