anybody know how im going to go about swaping a obd1 ls motor into my obd2 integra? looking for some good advice
question
most of the plugs are the same but all you gotta do is take anything from the obd2 motor that the obd1 is either missing or is different and put it on there...you can run the car with your stock ecu as long as all the sensors are correct and your useing the obd2 intake mani...if not then get a jumper so you can use the obd1
