Wat do i need and tips plz
Help converting 96 climate control to 2000
dam u legit have to change EVERYTHING. heater core, vents, cabin harness is the main things. if ur keeping your dash and swappin everything in then u gotta find a way to bolt up the 2000 climate control to the 96-98 dash cus they bolt up differently. what i did with my boys car was i used the steel bracket on the 98 dash that in the middle of the hole and bolted it up upside down to a lower bolt hole with 2 10mm bolts and nuts but didnt bolt the climate control up just spanned it in place. but if u swappin the dash too then u should be fine. just dont forget to swap the vin lol
