Wiring problem...Please help.
  • #31
    Bumpp cause i hate having wiring problems ,i just fixed my wiring problem & took me like 2months to find the short . .
    98Ex DD EJ8 ROADRUNNER
    • #32
      i hate that shit too. i hate knowing sumthing is not working properly. could be the cluster too. i gotta look over the whole car carefully
      Down Since 09 ...
      Mugen Inspired DC5
      • #33
        wiring is a bitch
        • #34
          let me know what ya find
          • #35
            Will do.. thanx for the help guys.
            Down Since 09 ...
            Mugen Inspired DC5
            • #36
              Problem 1# Thats kind of weird lols and creppy but the problem should be behind the cluster or around the steering wheel and the brake , the wiring should be over there . .
              problem #2 ... Did you check and see if its the right size bulbs thats in the tailights ? ?
              Bumpp cus i knew thats was the problem . lols . . .Damn im good lol! now can you hook me up w/ a pixel car lol
              • #37
                i jhus thought about it and makes perfect sense because if the tailights arent two point the wont dim out. theyll be either on or off.. damn u guys are smart lol.
                Down Since 09 ...
                Mugen Inspired DC5
                • #38
                  hmm. just chck everything. behind cluster, your dimmer wire at your radio harness, your bulbs, your bumper light harness, your headlight switch. Too bad you're so far away.
                  • #39
                    i hate this shit its annoying. i really dont feel like fucking wit it right now.
                    Down Since 09 ...
                    Mugen Inspired DC5
                    • #40
                      bump.
                      check your tailight harness..
                      your radio harness
                      and all ur bulbs.
                      • #41
                        ^^^^ already been said
                        • #42
                          Originally posted by jdmjunkie9753 View Post
                          Your best/easiest/most reliable bet is to just replace the underdash harness if its hacked up..
                          X2
                          Originally posted by NHSwaps13203
                          bump because i can fit your itbs in my itbs.
                          • #43
                            ^its not hacked up it was cut in sum places for the alarm but i removed the alarm and loomed everything back up.
                            Down Since 09 ...
                            Mugen Inspired DC5
                            • #44
                              I hacked up a radio harness and everything went nuts. When u turn the key the lights would go on the clock didnt work shit was crazy I was only 13 tho. I would suggest going to the junkyard find a radio harness and put it back In ur car then eliminate your options from there
                              97 Boosted Hatch my toy
                              • #45
                                My guess its the car had remote start before and hack the wiring on the brake switch check the wiring under your steering wheel you no by the pedals
