turn signals not working
  • turn signals not working
    busting my head trying to figure out why my turn signals don't work. played with hazard switch nothing only thing I can possibly think off is the dash harness is screwed up and possibly the cabin harness or it just a bad ground maybe someone on here know something about it that I don't know about would appreciate some help and advice
    did you check the fuse??
    The Power of Dreams
      check the fuses none are blown
        Try putting in a new hazard switch in and/or checking your turn signal relays..
          stupid ? bet you already checked but you never know. are the bulbs blow?
          S3-R
          Stage3-Racing
            Only time both signals won't work is if the hazard button isn't plugged in so it's either the hazard button itself or the wiring to it
              ^^x2. I got a hazard switch lmk
