My car keep popping the ecu fuses, everytime when i plug in the ecu to the harness and start it, it wont turn over cause the fuse keep blowing everytime when you try to start the car. need help asap, its a ek coupe with a b series vtec swap, i try the original ecu which was starting the car up before all this happend and a new ecu i just bought wont start. Both ecu start in my friend car, which is a ek coupe with a single cam swap..
UPDATE: 5/24/11
Now i installed a new car battery and now the car not cranking over or nothing, all the lights come on, where the dashboard is,(cel,battery,oil,all them lights)so when i turn the key the fans comes on and thats it,i hear spark, then when i turn the key and leave the key how it is, seems like the lights starts to dim then a noise from the right hand side of the car, seem from the fuse box in engine bay, idk the car was cranking over before i install this new car battery.. So need some answer, can it be the starter or the starter fuse or a relay, need some answers!
UPDATE: 5/24/11
