2000 harness question!! need help!!!
  • 2000 harness question!! need help!!!
    Not sure what is the right section for this but my question is.... is a 2000 coupe under dash harness the same as a 4door harness ??? I got a lx 4door and need the under dash harness and I found one off a coupe ... will I run into any problems ??
    As long as the coupe is a 99-00 like your car you won't have any problems
    TURBO 2001 IS300
      Ya..2000 coupe
        I had to do this to my coupe had all hacked up wiring I took the harness off a 2000 sedan everything plugged right up works the same vice versa good luck its workkk lol
        TURBO 2001 IS300
          I kno its work... trust I'm not tryin to do it but I can't let the car rot away so I'm stuck...
            Tttttttt
