Just replace My Clutch master cylinder and slave cylinder, I have been bleeding the system for two days on and off, still no pressure what could I possibly be doing wrong? Ive done to previous cars ive owned and they werent as hard as doing this car. By the way its a 93 prelude w h22a4.
Clutch master question
Originally posted by jdm*worxsjust replace my clutch master cylinder and slave cylinder, i have been bleeding the system for two days on and off, still no pressure what could i possibly be doing wrong? Ive done to previous cars ive owned and they werent as hard as doing this car. By the way its a 93 prelude w h22a4.WILSON BUILT
Try gravity bleeding it first.
With the bleeder open, filly depress the clutch and then close the bleeder.
Repeat that until you get some pressure.
If you have NO pressure at all you may want to pull the master back off and bench bleed it first.
You have to bench bleed master cylinders for brakes and ive always bench bled clutch masters too.RIP NHSWAPS13203
well if u got a new master cyl and a new slave cyl then check that all the lines are tight all the way from the mast cyl to the slave cyl. and check is u have any leaks somewhere on the line. if nothing then make sure the flares on the lines are good to make a good seal.
