wazup guy im having problem with my Cl S ii think i need to adjust the cluthch pedal rod or fix the master/slace cylinder cause today wen i turn the car on an let it warm up... after a few i went to put it on first an it wouldnt take it so i turn the car off an put it on gear, then got on the highway an shifted to 2ng gear fine with no grinds i went to shift to third it grinded like crazy an it would take no other gears so i turn the car off put it on neutral put it on 4th gear an turn the car on an then shift find so im not sure what it is going if its master/salve cylinder or adjust clutch pedal rod need help
Need help !!!
Idk bro but adjusting the rod is not fixing the problem it is more like giving a temporary solution to a problem that in all cases mite not even work due to it bleeding down then that rod will not move regardless. try checking the slave and master it can be something very simple you never know.. i hope everything work out and you get back on the road promptly cause being without a car kinda sucks when it's cold..860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
