hey like the title says....i got my teggy back after 8 months in a shop. i drove the car back home n it was fine but after 2 days of not starting it when i went to warm it up, it turned on but it only let me rev up to like 3500 rpms then it slowly decreased until it shuts off im running a p73 2b n it throws a p1607 code i changed the ecu 2 a p28 with a stepdown but it does da same thing. Any1 know wat the hells going on? lol i need dis car running asap any help would b really appreciated...thanks ctv
2000 integra wont stay on
3500 ...... most likly a dizzy if no change with ecu. switch with a well know one and write backMy transmission's went 9's
http://youtu.be/z2PHemIp_Tg
1. check the battery with the car running with a voltage meter on direct current and see if its between 13.4-14.9 volts if not dizzy has a bad connector or is shot.
2. check the engine gounds.... mainly the ground on the thermostat housing make sure its tight.
3. does the rpm needle jump around when its running/ideling????????EM1-860-CTmember..1...
J-SWAPS ....860-457-8335
