Cluster Problem!
  • Cluster Problem!
    I have a 94 ex coupe, stock cluster and everything is stock. Yesterday i bought a headunit,was trying to get it to work by messing with it, and couldnt get no power, then my cluster lights that lights up the rpm and the speed and climate went out.Only lights is the signal,srs,highbeams, and on the climate buttons when you push them in. Does anybody knows the problem why its not turning back on. i try the dimmer, unplug and plug back in and still not light, check the fuses and the bulbs, there good. . Can it be the wiring?
    When i got the car the same problem im having now i had before but all i did was messed with the dimmer switch. .
    PLEASE NEED HELP ASAP!
    98Ex DD EJ8 ROADRUNNER
    Somebody help me. Cant drive at night like this. Cant see how fast im going. . .SUCKS!!!!!!
      Yo tape a little flash light on the stearing column facing the cluster until u get it fixed Ohh nd I'm fresh oudda ideas
        Lols. Its a brand new harness under the dash. And imma try it, hopefully it works.!
          the orange wire off you radio plug what do you have it going to?
            i didnt do the wiring. thats how i got the car. the previous owner told me its a brand new harness & probably a lost connection.
              might be the dimmer that messed up. since there is a wire for the dimmer to the unit correct?
                imma get help today by my cusin so maybe when can get it fixed. but cant be the dimmers unplug it and look at it, really didnt take the dash out yet, to much lol and i been busy but ill try today since i have time and i never messed with wires before so lol.
                  ^^^^lmk what the deal is cuz my boys coupe has almost identical probs.. we cant figure it out!!!
                    Because i remember the dimmer was messed up on my eh3 and i had gotten another one and my cluster llights started to work again...
                      Didnt get a chance to try it to fix, but tomorrow i will. . .& let me know if your friend fix his. . .
                        will do.. we ripping it apart on sat cuz its suppose to be in the upper 40's... hopefully we will find something...
