Car wont start check video
  • Car wont start check video
    close
    Starter.. Did you try pop start? Check fuse under dash for starter
      Was it just crankin n is your batery charge
        Or is the ground on the starter on
          check grounds battery fuses starter is it gettn gas check harness if everything is plugged in
            man these guys dont know much lol check ur camshaft position sensor..make sure the wires are not broken..also u can unbolt the fuel line that goes from your fuel filter to the rail and have someone see if fuel comes out..if it does its electrical....it sounds like a sensor issue...retrace your steps..if it was a group it wouldnt turn on an crank over...if its fuel it would turn on and shut off...if ur getting fuel then ovb its not a fuel pump or clogged injector...what did you do to ur car the other day??? also if u took off ur dizzy u need to make sure its put back ur timing could be off if it dosent run (future ref) just leme know...860-819-7791 i got ur back
              Thanks alot and all i did was take out the intake and cleaned and put it back on.
                dident notice the car was turning over till i watched it at home.. the cam sensor for d/b series hondas is in the distributor btw.
                  Is this fixable at home or do have to bring to a shop because I dont have money to drop on a tow truck
                    did this happen all of a sudden? spark or fuel is what your loosing causing engine to die, fixable at home.
                      u can do it all yourself..grab tools...check ur tps sensor u prolly disconnected it...tps is throttle position sensor...its near the throttle body...its prolly something really small...cause if u took off the intake to put a new one on u disconnected a sensor or u hit something by accident..
                        it would start but bog and run like shit with tps unplugged. check map sensor on top of throttle body if its unplug it will not start for more then 2 seconds like in the video.
                        did you try starting it while holding throttle down?
                          Yeah it happened all of a sudden
                            I dont know much about cars like you guys do but I just turned on the car like I always did. In neutral pushed the clutch and started it.
                              Check the fuse under the hood. the 80A. That what happend to my coupe. till i replace it, and now it starts. . .try that
                              98Ex DD EJ8 ROADRUNNER
