Help
  • Help
    I try starting my eg hatch this morning and had no power so i tried giving it a jump still nothing ...checked all my fuses and relays and noticed that the ignition/battery relay was blown so i replaced it and it blew it again so i soldered it and tried it again and it blew the motherfucker again....WTF IS IT ITS COLD AND IM TRYING TO FIGURE THIS SHIT OUT HELP
    Anobody?
      check your ignition wires under your dash some thing is touchin
        Bout to check that it started up marking battery then it shut off
          its showing baterey because some things groundin out n thats y your fuse poppin
            is your battery,alt,grounds,good
              I know somethings touching I just can't figure out where
                Yeah I took it off and. Re grounded it
                  you got to check the wires under the stearing colum that goes to the ignition do u got a alarm
                    I'm doing that now and yeah I have a alarm
                      Happened to me b4 turned out to be a wire touching the power on my altenator
                        That's the first thing I looked at..lol
                          check the alarm wires they some time ground out to that metal plate under the the dash n stering colum
                            Doing that now
                              Problem solved thanks
