no heat!
  • no heat!
    why doesnt my heat work?? i got auto heat from a 2000 not mechanical from like 98, everything turns on and just blows cold air no matter what? the wire isnt sticking anywhere it moves that valve open an close still in the engine bay, what else could it be? heater core?? lmk its to cold for this shit..
    It's pretty cold out for no heat.
      check your coolant make sure it isnt low
        good call... il check it in the morning
          bad heater core.
            thats what i was thinking but i hope not! i dont wanna take my dash out!
            bad heater core.
              do u have ur thermostat on
                That blows... *pun intended*
                  yeah, heat was working earlier today all day and kinda just stopped
                    Check under the the dash where the heater core is theres 2 more cables make sure they are woking or check the stat see if the hoses are getin hot that go into the fire wall. Heater cores are only bad if they leak.
                    J-ROC TUNING
                      wrd thnks bro ... yea h.c isnt leaking so it gotta be something stupid
                        No prob bro G/L
                        J-ROC TUNING
                          check yo termasstatic pressure releaser.
                            yea check the valve by the firewall make sure its fully opening
                              i had the same problem. check ur thermostat that was my solution.
                              Down Since 09 ...
                              Mugen Inspired DC5
