car keeps shuttn off need help
  • car keeps shuttn off need help
    switched da alternator so far wat else could it be lemme kno plz
    does it die when you driving or at idle?
      it idles but im check fuses now
        altenator light on?
        Follow me @bolacan413
        Follow the build @k_insight
          im confused,,does it die while driving???if so id check ur coil,,main relay,,icm, etc
            gl on solvin ur problem
              need more info, does it die while driving,idling,randomly... does it shake before it happens or does it just suddenly turn off
              did you do anything to the car right before it started to happen....etc etc
              more information = better/faster response.
