My Bubble Is Leakin I Went To Get A Oil Change The Guy Said My Oil Pan Is Bad Is That A Easy Fix?? Do I Just Replace It Or Wat Should I Look For...
Need Help My Asap Bubble Leakin...
clean the bottom really good power wash it if you can start it up an look for the leak around your pan and in between the tranny and motor if you can get a rag and dry it off a bit before you start the checking process860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
