I was at da store today and as I parked and pulled up da e brake the car shut off..but I didn't think anything of it so I went in da store and when I came out it wouldn't start. buuut I didn't hear da main relay clicking so I'm not sure if that is the problem or is it my ignition cuz my starter had stopped workin last week and I found out it wasn't gettn power when I turned da key so I hooked up a switch in da meantime cuz I'm a busy guy...but yea I don't know what to do guys help!!! its still in da lot!!!
car won't start need help ASAP
theres a few ways to tell if its ignition, you can look in the helms manual for the wire color coming from the steering column, also when you goto start your car, your starters cranking?, and your positive your fuel pump is not working, are all your dash lights coming on with the key?
does your check engine light come on and then turn off when you put the key in the on position, are you running an after market jumper harness for your ecu?
do you have a test light? or meter? check for 12v switched power to the relay --- also helps to check ignition
Originally posted by gunitsolja View Postyea its still not startin...is the ignition hard to change??
NAH ITS NOT HARD YOU JUST GOT TO KNOW WAT YOU DOIN DO YOU GOT A ALARM N IF NOT TAKE THE PLASTIC OUT FROM THE STEERIN COLUMN N THERE IS GONNA BE A WHITE PLASTIC PEICE ON THE BAK OF THE IGNITION N TAKE OUT THE TWO SCREWS N WIT A FLAT HEAD TURN THE INSIDE OF IT N IF STILL DA SAME WIT NO START FOLLOW THE WIRES N CHECK THEM
does the motor turn over if not prob Ignition, if it does prob bad fuel pump dizzy, but check ur fuses first, there is this one gay fuse, i forgot the name of it, its called starter control module or suttin stupid like that, but if it is bad it wont get spark or turn fuel pump on, so id check all the fuses. Also is there a check engine light, if so see what its for
