i changed the Idle control on my 91 DA and i still have the same problem, the engine is a 95 b18b1 it idles a little over 1000 rpm.
idling issue! i need help
First things first, verify that your new Idle Air Control valve is working. With the engine running, remove the intake tube, and there is either one or two ports in the throttle body. One is for a Fast Idle Thermovalve (if equipped) and the other is for the IACV. Place your finger over one hole at a time and see if there is any changes.
Report back!
Originally posted by speedslow View Postis your idle surging or just high idle? .. i had a iacv code changed it twice still didnt fix it so when i got my car tuned by dave he found the wire had a break in it . ran a new wire now its minty
If it does not stall out, you may have a minor vacuum leak as well.
could be a number of diffrent thing first get a can of brake clean and see if u have a vaccum leak anywhere check all connections and wires if u have a map sensor that was removed make sure that the little rubber gasket under it is sitting flush in the cutout for it then take the intake tube off and do as the previous guy said also see wat happens when u apply a little pressure to the tps sensor
