Search in Technical Information only
Technical Forums
Misfire in cylinder 1....
turbohatch900
Dec 2009
02-25-2010, 08:00 PM
fixed
turbohatch900
04-09-2010, 02:18 PM
LS/Vtec
I <3 Haters!
02-25-2010, 08:05 PM
oil in the top of the plug by the plug wire? if so then the spark plug tube gaskets need to be changed. If on the bottom of the plug. Then your getting blow by then you prolly got blown rings.
turbohatch900
Dec 2009
02-25-2010, 08:08 PM
On the top.... g/l
LS/Vtec
I <3 Haters!
02-25-2010, 08:13 PM
yea then your spark plug tube seals. just get a valve cover gasket kit from AZ and it'll come with em. Takes like 5min to do.
turbohatch900
Dec 2009
03-22-2010, 07:31 PM
just needed fuel injector
