96 civic headlight issue HELP!!!!!
  • 96 civic headlight issue HELP!!!!!
    My buddys 96 ek coupe is having headlight issues. When he bought the coupe it had the hid's hard wired to the harness. He sold the hid's and now his headlights dont work. He got junkyard harnesses to replace them. What should we be looing for in order to get them working correctly. Please Help!!!!!!
    google h4 wiring diagram and it should show up with what wire goes where.... then turn on the headlights with all the wires apart from each other cause if grounds touch positives youll have issues... then grab a working test light try iton a battery first to make sure it is goona. clip one end on BARE metal on the car to insure good ground and then touch to the wires find out which one lights up and mark it with tape. then switch onthe highbeams and do it again and mark that with tap....
    thisw should be the link to the diagram if it doesnt work ill repost it
    8606177780
      ok the link works the wire marked as COMMON is aka for ground lol
      8606177780
        if you got the plugs off a ek then just match the colors and your good. It's easy as fuck to do.
          tru tru but at the same time whats not to say some dumb ass didnt hack those too lol
          8606177780
            hack em where? all the way back into the car? I doubt it.
              if its easy as fuck to do, than u do it lol, all the wiring in the car is fucked up, the car was owned by some mexicans that didnt know whut they were doing and the destroyed it to the point of where i dont even kno what anything is anymore
                lol u shouldnt have bought it then
                  where you located ill come fix the dam thing it takes like nooooooo tools to do it
                  8606177780
                    webster mass, on the thompson boarder
