fan help
  • fan help
    my fan always stays on i think its somekinda senser or somthing.... anybody got any ideas? or pics of where it is
    wut car
    1993 HONDA CIVIC COUPE "SMASHED"
    1991 EAGLE TALON "SOLD" IDK
    1992 ACURA INTEGRA "SOLD"
    1995 ACURA INTEGRA "STOLEN"
    1989 HONDA CIVIC "HATCHCITY" LOL
      o my bad and its a eg with a gsr and lstranny
        it stays on even when the car is off or only the whole time the car is on
          only the whole time it on... so it never gets hot enough to hit vtec
            well vtec should still work as long as ther's oil pressure...did this all of a sudden start or did you do something and then it happened...sounds like theres is something backwards with wiring
              it could be ur water temp sensor its located on the head gret plug next to one little black wire with one pin could also be ur fan switch its located on top of th thermastat housin also greyy plug with like two ground on top of it
              B SERIES INC....
                and not to be an ass blk but vtec wont hit unless engine temp is at operatin range
                B SERIES INC....
                  check the wires at you thermostat housing plug. See if they twisted em together. If so that makes your fan constant to ignition. Untwist em n tape em up.
                    g/l
                      thanx for the help any body got pix so i could know what im lookin for?
                          thnx
                            the fan comes on with the ignition on?
                            Ef/Ek/DC5
                              yea
