Ef sidemarkers help
  • Ef sidemarkers help
    I need help on my sidemarkers. So I finally got around 2 installing my sidemarkers 2 day. I ran em jus like I had on my hatch 2 da bulb in da corner light that stays on and blinks. But when I did it this time both bulbs would het dim like there wasn't enuff power. I finally found on da Internet that I could use a spdt relay but I can't find how 2 wire it up nehelp or ideas I'll appeciate thanx
    is there a good ground
      check your wires or ground... def dont need a relay for sidemarkers.
        Thanx I found out a wire that wasn't taped up from my deck was shortin it out. Hooked it all up n it's workin fine now. I'll try 2 get some pics in da members area soon.
