vtec problems
  • vtec problems
    my vtec pops then it sputters on and off really quick.. i checked the oil it had enough so it isnt that.... any1 have any ideas on what it culd be????
    its still doing that??
      head gasket is bad your losing compression what plus are u using?
      All Motor K
        yea i figured that it wuld be my head gasket... thanks bro im usin ngk's
          so thats wat might be wrong with my bros car is liking oil through the head a little bit tho and is also leaking from the vtec solenoid so idk...
          cripple member : P
            it might be the pistons and bearings.. check those too
              Which engine and car do you have? Might be a vacuum line, the solenoid or fuel injectors might be clogged and stuff. My friend had the same problem but it was cause his cam caps were on backwords, but I doubt thats your problem.
              Greatness is only 1,320 ft. away!!!
                wow... i'm amaze with the diagnostics on here. just wow...
                  i got a b16a in it..... its burning and leaking oil.. my vtec pops on and off realli quick..... im losing anti freeze but it isnt mixing in wit the oil..... i realli dont no wtf is wrong wit it....
                    argi you got blow by. is not your vtec your motor is about to go, plus your car is smocking. here is the deal from what i seen last night.
                    your car starts acting up around vtec range thos macking you thing is your vtec... but it also does it while standing still on a stock ecu (vtec won't pop while the car is park it needs to be rolling on stock ecu). we got to check your compression but i put money thats your problem.
                      ************ it imma burn dis ***************...
                        Yo, Before you burn it,
                        I'll trade you my car for yours, the 4 door you seen last night at my house.
                        Same motor, but runs mint.
                        Just a thought.
                          Just a thought.
                          lmao im jus playin dude im not gonna burn it.. yet ill let u no
                            wow is right there is some high class diagnostics goin on in this thread, lmao
                            337_runner
                            HIGH OUTPUT CREW #1
                              ya well if u culd do my car on monday imma keep the gsr head.. i jus need u to fix w.e has to be fixed.....:confused:
