automatic ls into a auto eg???
  • automatic ls into a auto eg???
    my cousin has a 92 civic and he has a b18 swap automatic...the tranny does not shift gears,its always on 1st unless u manually shift the gears your self..how can we fix this problem?do i need to get a tcm(tranny control module)and what car's tcm is compatible with his car????let me kno
    Originally posted by knuckk
    wow good luck fixing that bro
      just buy another auto ls tranny. pretty sure noone want then so they will be a dime a dozen like most honda parts
        its not the tranny maybe the sensor on it but not sure my boy x has the same problem i cant figure it out ill do research anc let u kno
          bump. any info on this? i cant seem to find shyt on any forum on how to do this
            the problem is the tcm..transmission control module located in the passenger side of a teggy in the kickpanel..so u basically have to get a helms manual and wire the tcm with the harness that it brings to the ecu harness..a pig P.I.T.A,,but thats the info that i have found out so far..so its not a bad tranny or a sensor its in the wiring ..
