P0461 Fuel Gauge Sending Unit Range/Performance Problem
P0462 Fuel Gauge Sending Unit Circuit Low VoltageP0463 Fuel Gauge Sending Unit Circuit High Voltage
P0496 Evaporative Emission (EVAP) System High Purge Flow
P0497 Evaporative Emission (EVAP) System Low Purge Flow
P0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage
P0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High Voltage
P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
P0501 Vehicle Speed Sensor (VSS) Range/Peformance Problem
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0511 Idle Air Control (IAC) Valve Circuit Malfunction
P0521 EOP Sensor Range/Performance Problem
P0522 EOP Sensor Circuit Low Voltage
P0523 EOP Sensor Circuit High Voltage
P0560 ECM Back-up Circuit Low Voltage
P0563 Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Source Circuit
Unexpected Voltage
P0600 Multiplex Control System Troubleshooting
P0603 ECM/PCM Internal Control Module Keep Alive Memory (KAM) Error
P0606 ECM/PCM Processor Malfunction
P0661 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit Low Voltage
P0662 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit High Voltage
P0685 ECM/PCM Power Relay Control Circuit Malfunction
P0700 Automatic Transmission Control System
P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
P0706 Open in Transmission Range Switch Circuit
P0710
P0711
Problem in ATF Temperature Sensor Circuit
P0712 Short in ATF Temperature Sensor Circuit
P0713 Open in ATF Temperature Sensor Circuit
P0715
P0716
Problem in Mainshaft Speed Sensor Circuit
P0717 Problem in Mainshaft Speed Sensor Circuit (No Signal Input)
P0718 Mainshaft Speed Sensor Intermittent Failure
P0720 Countershaft Speed Sensor Circuit Malfunction
P0720
P0721
Problem in Countershaft Speed Sensor Circuit
P0722 Problem in Countershaft Speed Sensor Circuit (No Signal Input)
P0723 Countershaft Speed Sensor Intermittent Failure
P0725 Engine Speed Input Circuit Malfunction
P0730 Problem in Shift Control System
P0731 Problem in 1st Clutch and 1st Clutch Hydraulic CircuitP0732 Problem in 2nd Clutch and 2nd Clutch Hydraulic Circuit
P0733 Problem in 3rd Clutch and 3rd Clutch Hydraulic Circuit
P0734 Problem in 4th Clutch and 4th Clutch Hydraulic Clutch
P0735 Problem in 5th Clutch and 5th Clutch Hydraulic Circuit
P0740 Problem in Lock-up Control System
P0741 Torque Converter Clutch Hydraulic Clutch Stuck OFF
P0743 Problem in Torque Converter Clutch Solenoid Valve Circuit
P0745 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve A Circuit
P0746 A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
P0747 A/T Clutch Pressure Control Solenoid Valve A Stuck ON
P0748 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
P0750 Problem in Hydraulic Control System of Shift Solenoid Valve A Circuit
P0751 Shift Solenoid Valve A Stuck OFF
P0752 Shift Solenoid Valve A Stuck ON
P0753 Problem in Shift Solenoid Valve A Circuit
P0756 Shift Solenoid Valve B Stuck OFF
P0757 Shift Solenoid Valve B Stuck ON
P0758 Problem in Shift Solenoid Valve B Circuit
P0761 Shift Solenoid Valve C Stuck OFF
P0762 Shift Solenoid Valve C Stuck ON
P0763 Problem in Shift Solenoid Valve C Circuit
P0771 Shift Solenoid Valve E Stuck OFF
P0773 Problem in Shift Solenoid Valve E Circuit
P0775 Problem in the Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve B
Circuit
P0776 A/T Clutch Pressure Control Solenoid Valve B Stuck OFF
P0777 A/T Clutch Pressure Control Solenoid Valve B Stuck ON
P0778 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
P0780 Problem in Shift Control System
P0795 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve C Circuit
P0796 A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
P0797 A/T Clutch Pressure Control Solenoid Valve C Stuck ON
P0798 Problem in A/T Clutch Pressure Control Solenoid Valve C Ciruit
P0812 Open in Transmission Range Switch ATP RVS Switch Circuit
P0842 Short in 2nd Clutch Transmission Fluid Pressure Switch Clutch, or 2nd Clutch Transmission
Fluid Pressure Switch (Clutch) Stuck ON
P0843 Open in 2nd Clutch Transmission Fluid Pressure Switch Circuit, or 2nd Clutch Transmission
Fluid Pressure Switch Stuck OFF
P0845 Problem in 3rd Clutch Pressure Switch Circuit
P0847 Short in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
Fluid Pressure Switch Stuck ON
P0848 Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
P0872 Short in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
Fluid Pressure Switch Stuck ONP0873 Open in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
P0962 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
P0963 Problem in A/T Clutch Pressure Control Solenoid Valve A
P0966 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
P0967 Problem in A/T Clutch Pressure Control Solenoid Valve B
P0970 Problem in A/T Clutch Pressure Control Solenoid Valve C Circuit
P0971 Problem in A/T Clutch Pressure Control Solenoid Valve C
P0973 Short in Shift Solenoid Valve A Circuit
P0974 Open in Shift Solenoid Valve A Circuit
P0976 Short in Shift Solenoid Valve B Circuit
P0977 Open in Shift Solenoid Valve B Circuit
P0979 Short in Shift Solenoid Valve C Circuit
P0980 Open in Shift Solenoid Valve C Circuit
P0982 Short in Shift Solenoid Valve D Circuit
P0983 Open in Shift Solenoid Valve D Circuit
P0985 Short in Shift Solenoid Valve E Circuit
P0986 Open in Shift Solenoid Valve E Circuit
P1020 Valve Pause System Stuck Off
P1021 Valve Pause System Stuck On
P1025 Valve Pause System Sticking Off
P1026 Valve Pause System Sticking On
P1077 Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
P1078 Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
P1107 Barometric Pressure (BARO) Sensor Circuit Low Voltage
P1108 Barometric Pressure (BARO) Sensor Circuit High Voltage
P1121 Throttle Position (TP) Sensor Lower Than Expected
P1122 Throttle Position (TP) Sensor Higher Than Expected
P1128 Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
P1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
P1130 Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)
(Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1149 Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range
P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage
P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage
P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1158 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
P1159 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
P1162 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
P1163 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
P1163 Air/Fuel Ratio Sensor (Sensor 1) Slow Response
P1164 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1164 Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/PerformanceP1165 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1165 Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance
P1166 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem
P1166 Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction
/PCM)
Unexpected Voltage
P0710
P0711
P0715
P0716
P0720
P0721
Circuit
/PCM)
